Hello All
I am having a problem with reading reinforcement designed by leap bridge. After I got the model done using BIM work flow, I sent it to leap for design, then I got the design done and closed the leap bridge to update the model. After that I hit read reinforcement, but nothing is there, am I missing anything?
Hi Rafal,
The reinforcement is read only for the footings. If you have designed other elements in LEAP, they will not be created in OBM. This is something that we seek to implement in future versions of OBM.
Thanks much
