How do you get Leap Steel to print influence lines for a specific point on the bridge?
after Analysis is run please check Show Report -->Live load --> lane loading details.
Other place to check the influence line is in the staad file ( ex: FEMAnalyticalModelLL_deck.std) the program generates when the user runs the analysis
C:\Users\----------------\AppData\Local\Temp\LEAP_STEEL\00001b89
Thank you for the information. I was hoping to get output similar to the output linked in this similar thread:
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/25076/influence-lines-diagram
Currently , the influence line shown in Bentley communities link is not available in LBS.
i apologize for the inconvenience.
