I am using LEAP Bridge Steel, Version 19.02.00.06, and am having trouble visualizing elements of the bridge. I have stepped through each element of the Bridge Definition Window and the steel beams and diaphragms are not represented in the viewing window.
I also cannot seem to change the elevation of the substructure units from the Bridge Definition Window to get them to the proper elevation for the beams to bear on--does this have to be done in the Substructure Design option?
Any help is much appreciated.
User can change the elevation in the profile dialog box.
Please let me know if this is the information you are looking for.
Thank you, Vinay. I tried changing some elevations in there and it would only visally change the grade. The deck and the substructure still would not "meet", and the steel beams and diaphragms can't be viewed. Could I send you my file? Thanks again.
Please email me the file "Vinay.Mysore@Bentley.com"
