LEAP Steel Crashing when using Auto Generate for Vessel Impact Loads
Good morning,
After completing my superstructure design, I used the substructure design/analysis tab to import all of my loads from the superstructure into the substructure.  It pushes all the data into .rcp format. Then, I try to create vessel impact loads for a barge using the auto-generate function.  This causes the entire program (RCPier and Leap Steel Connect Edition V20) to crash and lose any unsaved data.
Has anyone else ran into this kind of issue?  How did you solve it if you were able to?
Nathan
Parents Reply Children
