Dear All, I am new to OBM, I have problem as above screenshot.I created the Beam layout as 5 Beams, but after I place beam to that layout, there are only two beams appear.Can you guys tell me, what causes the problem here.Thank you,
I have emailed you my reply, please check
I am also new to OBM and am having the same problem. I found that if I remove the support line skew, all of the beams show up, but that they disappear as soon as I add the skew back in. I have no idea what the cause may be or how to fix it. I just wanted to say that this is not an isolated issue as I have had it as well. Does anyone know what the cause is or how to fix it?
if you have a solution, could you post it here so I can see it as well?
Still no solution yet,I followed the the tutorial step by step, it still doesn't workAnd, i also make by Bridge Wizard, yet it doesn't work with the skew as well.
Hi ,
Please send me your working file to have a look at it.
vlad.grigoras@bentley.com
