<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Bearing orientation changes from OBM to LEAP Steel</title><link>https://communities.bentley.com/products/bridge_design___engineering/f/bridgemaster-lars-leap-openbridge-rm-forum/211329/bearing-orientation-changes-from-obm-to-leap-steel</link><description>I am using OBD 10.08.2.10. I have a bearing and plate defined that is oriented with the beam. When I sent the model to LEAP Steel, it appears to rotate the bearing and also switches does not follow the build order that is set in OBM. Can I fix this or</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Bearing orientation changes from OBM to LEAP Steel</title><link>https://communities.bentley.com/thread/640098?ContentTypeID=1</link><pubDate>Fri, 19 Mar 2021 09:18:52 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:3b71ee82-9bf6-4c2e-b6b2-8c6403584465</guid><dc:creator>Vlad Grigoras</dc:creator><description>&lt;p&gt;Hi,&lt;/p&gt;
&lt;p&gt;Please send me your working file (including referenced files) to vlad.grigoras@bentley.com and I will have a look at it.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
