File location
Is it possible to change the default location where OpenBridge Designer stores its working files for LEAP Bridge Concrete and LEAP Bridge Steel?  Currently the program creates a temporary folder on the users hard drive and stores the *.lbcx files there. This doesn't change even after you export the files to a network directory.  This creates problems when sharing the files between offices and revisions are made resulting in multiple versions of the same file.  Can we set OBD to always read and write to the network location?
Parents Reply Children
