LEAP Steel Bridge Contraflexure points for dead load?
Is there a way to get the exact contraflexure points for dead load for a given girder on LEAP Steel bridge?
  • One way the user can get the points of contraflexure is by going to Analysis Dialog box -- > Show Reports à Dead load à Girder forces .
    In the Report generation window please select the option “YES” for Mz Diagrams and now the moment diagram will be generated for different load condition.
    User should be able to measure the point where the POC is located.
    Also in the Table user should be able to see the POI where there is a transition from Positive to negative values.
    Answer Verified By: MarcosBeier
