I am trying to model a rectangular straddle bent cap with variable section, since we need an inverted-T section below the deck to suppport the girders with no choice of using rectangular section due to vertical clearance issues.
I see the option to model the sections: rectangular, inverted-T, variable, but not a combination of those.
Is there a way of modelling this in OBM?
Suggest trying to model with the inverted T cap, and then use the Modeling > Solid tools to clip out the portions that you don't need. This should be done at the very end, since any updates to the model may result is loss of the clipping action.
Answer Verified By: MarcosBeier
Thank you Sri. We will try the solid tools.
