When modeling bearings with seats and tapered plates I have noted that at some locations the bearing seats seem to float above the top of the crosshead. Does anyone know if this is just a graphical issue and the heights of the bearing seats are being calculated correctly or is there an error in the calculation of the heights of the bearing seats?
The image below shows the bearing seat floating above the crosshead.
PDF
I haven't seen this myself, but a good solution would be to model the pier as a parametric cell that includes the bearing seats. That way you control that geometry as opposed to having the program try to calculate it for you.
OpenBridge Modeler - 10.10.00.85Microstation - 10.16.02.34
Comprehensive 3 Day OpenBridge Modeler Training
Can you send me the OBM model? vlad.ursachi@bentley.com
This is happening because your deck has multiple slopes and then user can't just make the pier cap to follow the deck. So, at Properties, Edit the Elevation Constraints.Thank you for your Service Request.
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 1 day ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
Answer Verified By: David Taylor
Thanks Marcos. That explains what is happening. I flattened my deck cross section and the bearing seats are now flush with the top of the crosshead.
