Hello Bentley Community,
I have come across this error message, while trying to use the Auxiliary Place Path tool in OpenBridge Modeler.
I first created a custom 3D cell and added it to the "Auxlib.cel" file and then tried using the cell with the Place Path tool and that is when the error popped out.
Have any of you come across this message before?
Thanks!
Can you send me the OBM model and "Auxlib.cel" file? I also need to know what you want to do, a picture or a video would be great. vlad.ursachi@bentley.com
Did you ever get a resolution to this error? I am getting the same error when trying to place an accessory by point or path.
Good Afternoon Vlad,Thank you for reaching out, I have fixed the issue, it was a software version issue.
Good afternoon Josh,
I was not able to figure out why it happen on the old software version but I upgraded to the latest version of OBM at the time and the problem went away. I am now running on version CE 2021 Release 1 V10.10.00.26
I'm hesitant to change versions to often for the same reason that there are to many bugs in newer versions, but this was one of the few times when it was helpful to upgrade.
I hope this helps,
