I edited the file BRIDGE_FEATURES_LEVELS_ELEM TEMP METRIC.DGNLIB and added an item type on one of the feature definition i created.
When i created a bridge model and modeled a deck, the said item type does not appear on the properties of the element.
but If i use the command "Attach item type" and attach the item type manually, it works fine. Any reasons why it doesn't work automatically?
Hi Cristiano,
Did you add the Item Type to the Feature Definition after the Deck was already created?
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
That workflow is in the process of being implemented for a future release...hint ...soon.
Answer Verified By: Crisanto Aquino
Hi, I created the deck after adding the feature definition, i even created a new file but still doesn't work.
