Vertical clearance to road
Good morning,
Is there a way that OBM gives the minimum vertical clearance (value and position) along the axis of a cap and the axis of a beam with respect to the road?
We have found that the Clash Detection Tool is able to find clashes between utilities and other elements and we tried to use this tool to find the vertical clearance between caps/girders and the road below them. But the tool does not give information about the elevations of both elements.
Thank you.
