LEAP bridge concrete substructure controlling load combinations
I want to print the controlling load output for specific nodes of my pier model (the base of the columns).  When I selected the "Controlling Comb. Only" option under Printing>Analysis Results, then also input the desired node numbers. However when the results are printed all individual load cases and dozens of load combinations are printed.  Can you help me understand why so much info is printed?
