I am designing a Pier using LEAP Steel and RC Pier and I am having two issues with regards to the footing.
1.) Whenever I exit out of RC Pier the Footing Reinforcement I have designed disappears. Is there any way to ensure the designed footing reinforcement saves so I don't have to re-enter it every time I go into the model?
2.) Currently I can only see how to export the Load Combinations at the bottom of the Pier Columns (in the Analysis Tab in RC Pier) into an excel file. When I design the footing the output shows loads at the bottom of the footing. Is it possible to export the loads at the bottom of the footing similar to the bottom of columns? I am looking to send over the axial and moment reactions from the pier design to a geotechnical engineer and they are requesting the loads at the bottom of the footing.
Any help on these matters is greatly appreciated.
1) After the footing is designed and while exiting RCpier user has to update the file and save the file. Then the program retains the reinforcement information.
If this solution does not work then i would suggest you to please delete the LEAP folder from the %temp% folder using the below shown steps and try:
•Exit all LEAP sessions you may have open on the machine.•Open File Explorer and type “%temp%” and click on Enter:
•This will open the temp location for your login•In this folder delete “LEAP_BAK” and LEAPBridgeConcrete” folders.
•Open LBC and try again.
2) Regarding the second issue , Once the footing design is done click on the design status and copy (Crtl-C) all the table and the paste to spreadsheet.
I am using LEAP Bridge Steel not LEAP Bridge Concrete. LEAP Bridge Steel does not give me the option to "Save" in the RC Pier (Substructure Design/Analysis) Window.
Then please try this option.
•This will open the temp location for your login•In this folder delete “LEAP_BAK” and LEAP_FSOLVE/STEEL” folders.
•Open LBS and try again.
Please let me know the LBS version you are working on.
1.) This does not resolve the problem. I am working in Open Bridge Designer CONNECT Edition Version 10.08.02.10 & LEAP Bridge Steel CE V20 Version 20.01.00.07.
2.) My original question regarding the exporting data into an excel file was not about copying the output into an excel, rather about exporting the full output data. The output report that is generated only shows the governing load combinations. I was wondering if it was possible to access the output data at the bottom of the footing for all of the load cases, similar to how I can access the output data at the bottom of the columns for all combination using the Print button in the "Analysis" Tab.
I am having the exact same issue #1 that Adam had where any pier components that are designed in the "Substructure" module do not save after existing the Substructure. All of my loads will save, but non of the design screens (Cap, column, and footing design tabs). I essentially have to completely re-enter/re-design all pier components each time I get back into the Substructure screen. I also tried all of the suggestions by Vinay in the email chain, but none of them solved the issue. Any help would be appreciated. Thanks.
