Please be asked how to generate the custom precast I-girder with posttension in LEAP Concrete.
Thanks in advance.
WNI
Please follow this steps to model a Custom I girder with Post tension inleap Concrete.
1) ABC Wizard --> Select Post Tensioned CIP Box.2) Span = 1 , Number of Interior Girders 1 . Make necessary changes to the girde properties.3) Complete the modeling and then click on " CIP RC/PT Girder".4) Go to Geometry TAB --> Cross Section --> in the Cross Section Layout dialog box click on "Section" and then under " Exterior Girders" Under Type change the option to "None".5) The Box girder is now customized into I girder.6) Add the tendons and complete the analysis and design.
Thanks for your information. I will try. However, (I'm not yet try), I have some query. Normally, the structural system for I-Girder is composite. The deck and the girder is not the same material and not casting at the same time. So, I'm not sure if model as CIP Box, we can separate for deck and girder in different materials or not?
Currently that is not possible to have Different materials for deck and girder in CIP Box.
But this type can be provided in Prestressed girder option.
Thanks for your information. I had try also that cannot. I will try this in RM Bridge.
