I have tried this on OBD 10.08.02.10 and 10.09.01.15. I can create the OBDX file, but when I try and create a Group, OBD closes. In the Event Viewer, I receive the following
Faulting application name: OpenBridgeDesigner.exe, version: 10.8.2.10, time stamp: 0x5f45f6f1Faulting module name: KERNELBASE.dll, version: 10.0.18362.1474, time stamp: 0x5ae7af90Exception code: 0xe0434352Fault offset: 0x0000000000043b19Faulting process id: 0x1b84Faulting application start time: 0x01d751a596e31ef4Faulting application path: C:\Program Files\Bentley\OpenBridge Designer CONNECT Edition\OpenBridgeDesigner\OpenBridgeDesigner.exeFaulting module path: C:\WINDOWS\System32\KERNELBASE.dllReport Id: b5acf5ed-49cc-4617-b488-26fb9b5c3388Faulting package full name: Faulting package-relative application ID:
Any help would be appreciated.
Thank you
-Phillip Hess
