I am modeling a bridge and for some reason the bearing on one of the abutments is not showing. I am very careful and iam following the same exact steps as I did before (it's showing on one of the abutments and the pier) I already tried everything I could thin of: (I made the cap big enough so the bearing would fit, i left some room between the btm of the girder and the top of the cap) Has anyone encountered this? Help would be much appreciated!
Hi Elsy,
Can you provide some working files or screenshots of the issue?
You just have your parentheses () in the wrong place.
You are adding degrees to a value in radians, which won't work. toDegrees() will do the conversion from radians to degrees for you, then you do the normalisation once you have a value in degrees.
toDegrees()
