RM Bridge - Plate buckling analysis capabilities?
Is RM Bridge capable of conduct plate buckling analysis? see picture.
If so, could you please share any example or demonstration showing how to perform the analysis?
I found the following regarding Euler buckling load for column but buckling analysis considering buckling of plate element is totally different to say the least.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/52256/rm-bridge-verification-examples-1---euler-buckling-of-a-column
Thank you,
Marcelo
