I am working in OpenBridge Modeler Connect Edition (10.08.02.55) through OpenBridge Designer (10.08.02.10) and am experiencing an issue which causes the software to crash. I am attempting to model a bridge with different numbers of beams in the different spans. In this case spans 1,2, 5, & 6 have 16 beams and spans 3 and 4 have 14 beams. When I model the bridge with all of the spans having the same number of beams, the layout generates successfully. However, when I attempt to change some of the spans to a different number, the program crashes. See attached. If I press ignore, the program instantly crashes if I attempt to change any of the inputs for the 14 beam spans. Does anyone have any familiarity with this issue?
Dylan
Please email me the file so that i can test this issue on my machine.
My email is anacarla.peres@bentley.com
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
Was using old version of OBD, resolved by updating.
Answer Verified By: Dylan Kennedy
