I have modeled a wing wall using Drawing and Modeler Workflow, and I want to place it as a wing wall inside Openbridge moduler or even add it to the library so I can use my constraints. How can I do that ?
I see that the wing wall library can import XML files, How can I get over that? How does it work?
Ideally you would create a full parametric cell of the entire end bent or abutment and have that wing wall as part of that parametric cell. Then you would simply use the place custom abutment tool to place it. You may be able to get away with the place auxiliary tool but it likely won't produce the outcome you desire.
OpenBridge Modeler - 10.10.00.85Microstation - 10.16.02.34
Comprehensive 3 Day OpenBridge Modeler Training
www.youtube.com/watch
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
