I encountered a problem.The cross frames in the steel structure collided, so one of them is needed to be disconnected and connected with steel plates like the CAD drawing.However, the current software does not have this function, and I hope to add this function.
thank you!
users can apply connection plate . Please check the screenshot.
I apply connection plate,but the Diagonal not disconnect.So,the Left Diagonal and Right Diagonal is clash.
