Hello
I have created a parametric cell for a customer pier. However, when I place the custom pier in OBM, it places it horizontally instead of vertically.
How can I fix that?
Please look at the screenshots
PS : I tried to draw it in the X-Z Direction and I'm still facing the same issue.
The Custom Pier should be created in the XZ plane.
Answer Verified By: MarcosBeier
Hi Vlad, thanks for your recommendation, I have tried to draw it again in the X-Z Direction and I'm still facing the same issue.
If you changed the pier on the .cel file from the Program Data compress your DGN before replacement.
If you still encounter the same problem, send to me an email with the .cel & .dgn files and I will take a look. vlad.ursachi@bentley.com
You can do one more thing but personally, I don't like it.
1. make sure that your model from the .cel file is Parametric.
2. In the properties tab, click on the "Selection" and then you can change orientation from "Geometry"
But, if you draw your Pier in XZ plane, and in OBM you have these rotations, there should be no issues:
Please let me know what you did.
https://www.linkedin.com/feed/update/urn:li:activity:6762314862682091520/
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
