使用OBM创建“阶段施工桥梁”时,无法创建“挂梁”,这个问题该如何解决?
Please check the video at the link below about segmental bridge modeling in OpenBridge Designer
https://youtu.be/PIaxi8BPMw8
If you're asking about a transversal beam it's not yet available in OpenBridge Modeler, so you need to use RM Bridge as a standalone in OpenBridge Designer.
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 2 months ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
好的,谢谢
