Below is a drawing of a beam layout that has transfer girders circled in blue. Is the latest version of OBM able to model these transfer girders? This is one unit of my bridge that uses continuous beams over these 5 support lines.
Hi Dennis, you can email me your file for further investigations: anacarla.peres@bentley.com
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
Hi Ana,
I wish so badly that I could share my file but the client will not allow me to share any files from this job. I could lose my job if I did.
Is there a way that I could set stiffeners on the sides of beams 18 and 20 and then connect the stiffeners with a cross-frame somehow? Maybe if all else fails I will just draw it manually with solids.
