I'm trying to export a OBM model to Leap bridge Steel using the 'Send To' OBM's Interoperability. However, I keep on getting the following error: Database generation failed.
I have Leap Bridge Steel Installed and can be opened independently. I don't see any red-flags in my OBM model so far. I'm logged into my Bentley account. Any help would be appreciated.
Thank you
Charles, Please file a support /service request so our technical support engineers can reach out to you and get more information to troubleshoot.
https://apps.bentley.com/srmanager/ProductSupport
I am having the same issue for one of my models. If you find a solution, could you please share? Thanks!
Turns out I was missing bearing under the beams. Once i entered that in, it exported fine after that.
indigocard Wrote:
This works really well for me, thank you! Facing same issue here. Help is appreciated.
