which of Bentley products allows the design and load rating of C.I.P Concrete Flat Slab (using the AASHTO Strip Method)?
See also: communities.bentley.com/.../concrete-c-i-p-flat-slab
Bridge related ... the LEAP Bridge Concrete software included with OpenBridge Designer.
OpenBridge Designer includes LBC - LEAP Bridge Concrete where users can design a Deck Slab using the Approximate/Strip method as specified in LRFD. When the user selects the Superstructure type as a CIP Slab it simplifies the data entry for just a rectangular cross-section and performs a full-width analysis.
New Release: LEAP Bridge V8i(SELECTseries 1) v9.0.0 - LARS | LEAP | OpenBridge | RM Forum - LARS | LEAP | OpenBridge | RM - Bentley Communities
Slab Bridge - Exterior Strip width Design - LARS | LEAP | OpenBridge | RM Wiki - LARS | LEAP | OpenBridge | RM - Bentley Communities
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 2 months ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
Answer Verified By: Samer Attallah
