Unable to delete pier - OpenBridge
I've got this weird issue in OpenBridge where I cannot delete or modify this pier. You can see in the properties window that all the properties for the pier have disappeared so I can't edit the template or elevation constraints. When I try and delete it, I get the error "Command not defined for this application". Any ideas?
Parents Reply Children
