Hi all,
Is there a way to sort the files once created using the Standalone mode in OBD.
if I right click it, the only option is to remove a file. Also, if I create a new file, the new file will be placed at the bottom of the list and I can't SORT the files in alphabetic order.
Is this some that Bentley is working toward improving?
Thank you,
Right click on Standalone group and you should be able to Sort the files.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/51371/standalone-workflow-for-analysis-and-design
my current OBD version does not show the sorting option for the group. Also, I think the sorting you have shown seems to only sort the GROUP, not the files within the group. I am looking to have the files under the group sorted and also renamed.
see my OBD version below
CredibleBH Wrote:
Everything is very open with a clear description of the issues. It was truly informative. Your website is very helpful. Many thanks for sharing!
Hi Marcelo, there will be more options available in next release expected by the end of this year.
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
Answer Verified By: Marcelo F. DaSilva
Thanks Ana.
looking forward for the next release.
