OBM Girders Not Linked to Substructure
I have a file that was created with a 3 span unit.  Due to vertical clearance restrictions, I had to modify (recreate) the span to be a simple span and then a 2 span unit.  As I was going through and attempting to add the bearings, it would now allow bearing placement.  That is when I then noticed that the girders are not linked to the substructure because the end bent was placed very high.  Is there a way to recreate that link without deleting that entire span and recreating it from scratch?
