Hi, I work in a road departement and we are still using Openroads designer 10.09 (2020 release 3) My bridge team is using Openbridge Modeler 10.10 .
When they open their bridge file they get this mesage:
But appart from this message everything seem to be fine.
We are early into the project, but what problems can we expect if we continue this way?
Please check the Wiki article about it at the link below:
communities.bentley.com/.../update-schema-of-a-dgn-file
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 6 days ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
I do not want to update the schema, it's just that the road team NEED to deliver with Openroads 10.09, so I want to know is this a NO-GO (having different application roads and bridge with different civil schema) or a GO?
I know how to update civil schema, like I said now everything seem to be fine but have anybody tested this before?
