Our standard requires us to classify every object in the OpenBridge model according to an approved format. We are achieving this via Item Types which works well. However, when I upload the OpenBridge model to iTwin all of these item types are not visible. I'm not sure if they're lost or just not accessible. I then tried exporting to IFC from iTwin and this also did not contain the item types. I tried using the Prostructures IFC exporter in OpenBridge and this also did not carry the item types across into IFC.
Looking at this page here it looks like this is the solution: export item type to ifc - OpenBuildings | AECOsim | Speedikon | Forum - OpenBuildings | AECOsim | Speedikon - Bentley Communities
However, it appears that OpenBridge doesn't have these options.
If there isn't a solution to this at the moment, is there another form of export we can use that will carry Item Types with it?
Thanks for your help.
Also works on the Export to IFC. We can see the item Types.
When we could expect this 2022 release in year 2023 as it was for 2021 version?
I test the version (2022 Release 1),by opening the OBM file in MicroStation, and I can not see the Item Types for the footing selected in MicroStation.
Hi Sri, I just tested in OBM 10.11 and dont see this, can you double check?
Mark
This is out now. Release 2 will probably come of December 31 haha
