How can I add a strand at the red location shown as below (in between two default black dots)?
Jaya, you had posted in the Communities Feedback forum, which is intended for feedback about the site itself. For help with technical questions, post on the respective product Community forum. I assume you are using LEAP CONSPAN so I have moved your post to the LARS | LEAP | OpenBridge | RM Forum.
If you are using a different product, please clarify the name and version number so we can ensure your post is moved to a forum where a specialist can assist.
Assuming you are working in LEAP Bridge Concrete > Precast/Prestressed module. When you are creating/modifying a section click on Template and add/adjust the Height and # of Strands and click OK. Once changes are accepted make sure to Save the library.
How to add Custom Beam Section to Precast/Prestressed (CONSPAN) Library - LARS | LEAP | OpenBridge | RM Wiki - LARS | LEAP | OpenBridge | RM - Bentley Communities
Hi Dilip, thanks.
Can I ask if I can adjust the width? The location (red point above) that I try to add strand to is not available.
Hi Jaya,
You can specify the height where one can place the strands along with the # of strands. One cannot specify the location along the width where the strand is placed. W1/W2 dimensions in the main section dialog defines the width of the web and user needs to specify the # of strands in the template that could fit in that width.
