Hi, I would like to use this tool and would like information on the component center, Where can I find tutorial or information on this?
Also is there a possibility to use the Place Auxiliary By Path tool without the component center?
regards
Yes, users can directly access the Place Auxiliary By Path tool in OpenBridge Modeler from the Home Ribbon, at the Accessory Tab, as shown in the screenshot below. It uses the Cells in the Cell DGN library. You can find the basic information about the Place Auxiliary By Path tool in the OpenBridge Modeler online help, as explained in the link below. For quick access click the F1 button or Help inside the software.
Place Auxiliary By Path tool (bentley.com)
You can find more information about the Component Center in the MicroStation CONNECT Edition Help, as in the link below and the others related:
Introduction to Components Center (bentley.com)
Much more information can be found at the link below from our Wiki in the BeCommunities, check for all the related links for videos and more:
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/42270/creating-functional-components-for-use-in-openbridge-modeler
Marcos Beier
Senior Technical Support Engineer
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 7 months ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
