I would like to be able to hide individual lines in my section views in order to make the drawings look correct. One specific example is shown in the image. I'd like to be able to hide the line between the 2 elements so it looks like one solid element.
I understand that if you can model it 'correctly' you should, but its not always possible, and sometimes modelling it correctly means that it looks messy on a drawing.
In Revit, this is achieved by using an invisible linestyle on that particular line. It works very well and helps a tonne when creating drawings.
See here for explanation: https://www.graitec.co.uk/blog/entry/revit-tip-invisible-line-style#:~:text=The%20'Linework'%20tool%20can%20be,are%20changed%20to%20'Invisible'.
However, I don't think there's a similar feature in OpenBridge/Microstation.
If it's not possible, what do people use as a workaround for this?
Thanks.
Would the Clip Mask work?
I kind of does, but it's a bit messy and cumbersome to use for individual lines.
Another alternative, perhaps Display Styles/ Display Rules/Construction Class could be used to achieve this.
You could also try using the Unite command to merge the those two elements. That may have other undesired effects though.
OpenBridge Modeler - 10.10.00.85Microstation - 10.16.02.34
Comprehensive 3 Day OpenBridge Modeler Training
Yeah, using unite seems to destroy the parametric abilities of the object, which I'd like to avoid. If it didn't break the object smarts, it would be a good solution.
