For our projects we typically don't have haunches between the top of girder and the underside of slab. Instead, slab is simply poured thicker in those areas where needed to fill the gap. Is there a way to do this in OpenBridge so that the haunch does not exist, and instead the deck is shown thicker?
Hopefully that makes sense.
Updated deck overhang design to be in accordance with BDM view, an open bridge rail system approved by the CTDOT should be used in place of a.
