Various OBM issues and questions
Hello all,
I have a few questions and concerns regarding OpenBridge Designer (version 10.10.00.26) that I hope someone is able to answer. Please find my questions below:
  1. I have a situation where multiple bridges share the same substructure (abutment & piers). Is there a way to define multiple bridges but link them to the same support lines?
  2. Do any of the included OBD programs analyze and/or design post-tensioned reinforced concrete piers?
  3. I have experienced issues where the OBM was sent to LBC only to find that certain items that were modeled did not transfer properly. For instance, items like bearing pad and seat geometry, abutment backwall heights (when told to meet the top of slab), beam end offsets from the backwall, and a few other items did not transfer to LBC appropriately. I then sent the LBC model back to OBM (standalone option) only to find that my model was updated with wrong information, which had to be corrected. I have tried to pick and choose the items I want to transfer back to OBM, but there is not enough independence in the selection options. Though, the additional independence would not be needed if the transferring worked as intended. Is this a common issue and what are the solutions?
  4. I have also had an issue where the LBC models were updated and saved but when I attempted to open the model the next day, the information had not been saved. An image below shows that OBD stated the LBC model was updated at 6:13PM, but the linked file in the folder indicated the last update was at 1:58PM.
 5. The saving issue has caused me to not only “Save” but “Save As” the LBC models after updating. When I find that LBC did not save correctly, is it appropriate to delete the previous LBC file and relink the “Save As” file to OBD? Will there be any issues with this process?
 6. I do not understand why the haunch estimation in OBM needs to be so complex. Initially, a haunch is estimated in OBM for the beam placement. Then the model is sent to LBC (Conspan) to be designed. The camber tab in OBM allows the user to import the CONSPAN camber and DL deflection values. However, these values are not automatically sent to the beam definition, where the program updates the haunch. Instead, the user has to manually enter the required start/end haunch or camber for each beam while also verifying adequate beam to slab clearance. However, the haunch process has all the tools necessary to be automated. Another concern is with the option to specify Min. Clearance and Camber. This method does not account for the beam DL deflection at mid-span, which affects the haunch at the center of girder. This is of particular concern since some DOT's have specific ways of calculating haunch at mid-span.
 7. If I decide to use the BIM Workflow option, do I need to re-enter all of the loads in RCPier each time I update the model in OBM? Using the standalone option, changes in the OBM (i.e., horizontal alignment) have to be re-sent to LBC. This results in me losing all of my previous analysis and designs. There must be a better way?
Thank you!
