I have been trying to import the LBC reinforcement into OBM. However, I get an error message:
I have OBD (version 10.10.00.786) and Prostructures (version 10.02.00.20). Has anyone seen this? Could it be a compatibility issue?
The reinforcement is showing up correctly within the LBC geometry tab.
Thanks.
Hi William,
What workflow did you used, BIM or Standalone? Can you tell me what steps did you made before getting that error? Please be aware that currently, we support only the footing reinforcement for transfer.
I am using the standalone option working off the C - drive. I sent the model to LBC, did the designs, read the analytics into OBM and checked the import rebar option. This produced the error. Though, I was trying to transfer the girder and bent cap reinforcement, which is probably why I got the error. I didn't realize that only the footing reinforcement could be transferred.
