Coffee Corner: OpenBridge - Configuring Plans Production Tools in OpenBridge Designer
Title: Coffee Corner: OpenBridge - Configuring Plans Production Tools in OpenBridge Designer
PresenterSteve Willoughby, Senior Application Engineer, Bentley Systems, Inc.
Date and TimeThursday, December 02, 2021 at 20:00 PM EST
Register Now!
Every owner/operator has specific requirements on their submitals for 2D plans, from the CADD standards to use to the formatting of the text and sheets.  OpenBridge Designer can be configured to meet all these requirements in an automated way through the setup of the proper workspace.
Let’s review the configuration needed to meet all your plans production standards:
  • Setup drawing and sheet model seed files
  • Customize drawing details
  • Create text and dimension styles
OpenBridge Coffee Corners are open to all Bentley users, free of charge. One learning unit is applied to each participant’s Bentley Transcript for self-reporting. To view prior sessions, watch the Recordings On-Demand.
**The webcast will be streamed through your computer, so there is no dial-in number.  Please make sure your computer speakers (or headset) are turned on and the volume is set to an audible level so you can hear the presenters.  Help
