PDF
When designing the end bent of a bridge unit (continuous unit), how do you get leap concrete to read the live load cases from the previous unit? The program only models one bearing line and doesn't seem to have an option for import of the loads of the second bearing line. How do i import the loads from the other unit? See the PDF attached.
For more information related to Leap Bridge Concrete program please check the wiki articles in the below mentioned Bentley Communities link.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/11174/leap-rcpier-substructure
