How to export superstructure loads from Leap Bridge Steel to substructure design/analysis? it appears none of my loads (DL, LL, DW, TU) have come in from the superstructure. I see the option to import from text file. is there something I need to do in the superstructure module to export my loads to the substructure?
Thanks.
You are welcome, Mark.
Thank you for the constant encouragement to serve better to our Bentley users.
Well, of course I always make every attempt to help those which which help us, and- by such attempts- help themselves as well!
Best Regards, and Thanks Again,
Mark
Thank you.
I found this thread while getting ready to post a question, and although my question is not exactly the same, it applies as well. We are able to go to substructure design and analysis and export the geometry and loads with no problems (so far). The issue I have is that we cannot save the design/analysis as the main file tab (new/open/save/save as) is missing in that LBC opened up from LBS. I noticed that you do not have it either in your screenshots above. I was trying to export this from LBS and saving it under OBD so other designers would not have to go in to LBS at all, but could start with the base geometry and loads. But if I cannot save the file, they will not be able to open it. Can you let me know how to save that design/analysis in LBS?
I agree that the save/save as option is not there in LBC opened up from LBS.
User has to close the substructure module once the analysis and design is done and the program automatically saves the file under
LBS.
I hope it helps.
Thanks ,
Vinay
