How to export superstructure loads from Leap Bridge Steel to substructure design/analysis? it appears none of my loads (DL, LL, DW, TU) have come in from the superstructure. I see the option to import from text file. is there something I need to do in the superstructure module to export my loads to the substructure?
Thanks.
Thanks for the quick reply Vinay. We noticed that it did save information by closing it out ony because when we opened it back up it was asking us if we wanted to write over the existing information. One of the problems I was noticing with this method was that the only want to open it back up is to click on the analysis and design again. However, this overwrote the project information so I felt like it was not saving everything. Is there another way to open up the substructure design without inputting all of the information again? This also makes it very difficult to perform QC on the substructure design.
What we are hoping the program would do is give you the option to save to LBC so then it could be stored under OBD and also uploaded to ProjectWise. Currently, we have to start up LBC from OBD and manually input everything because the export feature seems to be extremely limited.
The program does saves all the information , i would suggest you to not to overwrite the existing information.
Please let me know if you are still facing this issue.
Vinay,
It does not matter if I choose Yes or No when it asks about overwriting the file, it never retains the previous data. The other limitation of this is that we have two different live loads to design for but you can only pull in one live load at a time. I had hoped to maintain previous results so that I could pull on the live loads at different times.
Please provide next steps on how to keep results. Also, does Bentley plan to increase the functionality of the program and save it as an LBCX file in the near future?
Hi Brian,
It is quite strange that you are unable to save the substructure data and the program is not retaining the information.
Please email me the concerned OBD file and the version number you are working on.
The feature to save the substructure data is already there and it looks like it might a file specific issue and needs to be investigated.
If you want any enhancement to be implemented in the program then please do add your request to IDEAS.
Please check the link to add your request.
https://communities.bentley.com/products/bridge_design___engineering/i/lars-leap-openbridge-opentunnel-rm-ideas
My email is "Vinay.Mysore@Bentley.com"
Vinay
Also i would suggest you to download and install the latest version from Bentley Select server.
