I am having an issue where my battered pile look correct in my OBM model, but when they are transferred to LEAP they are backwards. I used the same template for the begin and end abutments, and just changed the orientation in the properties. I tried to solve the issue by creating a different template for the end of the bridge, but there doesn't seem to be an option to define it in a different way. Has anyone else run into this issue or have any other suggestions?
OBM Model
LEAP Model
Dylan, what version are you using. I recall this issue was fixed in the 2021 R1 release.
Sri, It looks like I'm using the R1 release. I took a screenshot of it below.
Hmm, then most likely this is fixed in the our current development version to be released soon. We will double check this and support will reach out to you.
