OpenBridge Model plan line work ("Decoration lines"?) not updated after modifying 3D solid
Hi, all
Recently I am using OpenBridge to create the 3D model of a bridge. I used the modulus tools to create the abutments at first and then modified the solid to best match the bridge geometry.
For example, I chamfer the cheek wall by cutting the solid. The red lines shown below are the project lines from the 3D model, and the greens are the "Decoration plan line work". As shown below, the "Decoration plan line work does not update per the 3D modified solid.
I do have the same issues when moving the solid manually, and the plan line works wont update.
Did I miss anything like refresh or update the model?
