When I place an abutment template using the elevation constraints the location measures correctly in MicroStation, however the Pier printout does not appear to follow the restrictions I set. This means my pile elevations are also printed incorrectly. What is causing this error and how can I fix it? Thanks!
Inputs: Pier Elevation Constraints
Outputs: Pier Elevations Report:
Krista, We will need the file to look into this issue. Please file a support ticket.
Ok thanks.
