Hi, all
I have generated the model for 2-span, continuous span model. The negative moment reinforced rebar is supposed to be taken care of the negative moment. I have input the negative rebar but it seems in the strand pattern check, the program assumed the girder taken care of the negative moment? Or did I miss anything?
I would suggest you to add couple of tendons on the top of the girder and check if the stress reduces.
For more information and suggestions please check this below mentioned link.
https://communities.bentley.com/products/bridge_design___engineering/w/bridge_design_and_engineering__wiki/20064/exceeding-stress-limit-for-precast-top---negative-moment-envelope-condition-at-bearing-location
