when i plot rebar stress with RmSet, plotted values always show x10 times bigger than the values listed in lst file. I suggest you fix the minor bug.
Hi Lee, would you like to send us the *.tcl file for further investigations? You can email me: anacarla.peres@bentley.com. Best Regards,
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
any demo example which runs Rein. Plot the rebar stress and you will see. the values plotted using RMSET has exactly x10 times bigger. .lst output has no issue.
It will be investigated. Thank you.
Hi Lee,
For the latest versions, per our tests, and as shown in the images below, it's working fine with the same values for GUI, RMSets, list, plots, and .xls files.
So, please send us one file where we can create a Service Request to check the version and everything else to verify what's going on.
Marcos Beier
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 1 day ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
