I have used the Place Path tool to place a traffic barrier railing along my bridge. I now need to adjust the start station of the path. When I select the barrier and try to change the Start Station, nothing happens. All the other Rule Properties are working fine, it appears to only be the Start Station that doesn't work.
I used the place path tool with a Path Selection mode of 'Select Guideline Providers"', and stationing was from 'Alignment'. I can edit the start station if I place using the "alignment with profile option."
Is this an issue on my end? Or is this something that needs to be fixed?
If I need to wait for a fix, what is the workaround in the mean time?
Please add a post with how you decide to proceed and your results so other Community members may benefit.
I have just been using the ALignment with Profile setting. This one allows you to adjust the start and end stations. But it means it doesn't attach to the top of the deck or concrete barrier. It just attaches to the centreline. You have to manually adjust the vertical and horizontal offset to get it in the right location on the deck.
