I am currently working on a suspension bridge model in RM Bridge. When I run the analysis, it has error messages saying that the cable nodes need global DOF 3, but restraining DOF 3 using node support would cause the cables not able to move laterally at all. It seems that there is no transverse stiffness at the cable nodes in this model. I checked other suspension bridge models and it seems that only DOF4-6 need to be restrained.
Does anyone know what the problem is here?
Thank you Simon, for submitting a Service Request. Your file will be investigated.
communities.bentley.com/.../how-to-log-service-request
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
Answered by SAP.
For the analysis to include P-delta and Large displacements it would only work with the inclusion of the cables stressing normal forces.
Marcos Beier
RM Bridge - OpenBridge Designer RM Bridge is now an integral part of OpenBridge Designer CONNECT Edition as Bentley’s solution for supporting the design and engineering tasks in bridge construction for all types of bridges and construction… Last edited 2 months ago in LARS | LEAP | OpenBridge | OpenTunnel | RM > LARS | LEAP | OpenBridge | OpenTunnel | RM Wiki
