Hi,I am modeling a skewed multi span steel bridge with cross frames and bottom flange lateral bracings. I was able to place the cross frames but when I tried to place the lateral bracing based on a suggestion from Bentley community about bottom flange lateral bracing, I am getting the following message:
I am showing the framing plan for the bridge below, has anyone have an idea on how I can fix this?
Thank you,
Tewodros
Tewodros,
The program does not allow placement of intersecting cross-frames.
The message will change to “…intersecting…” you try to lift the first message “…located on the same point…”
I will add an enhancement request based on your framing plan documentation.
you can do it with RM Bridge.
communities.bentley.com/.../9-rm-bridge-steel-design---training-example
Ana Carla Peres
Senior Technical Support Engineer
Bentley BrIM
But I can only model one of the diagonals, otherwise LBS does not allow to model intersecting bracings.
I have not model in RM bridge bridge but I will keep that in mind.
